LALAL.AI's Vocal Remover Is the Advanced AI Splitter To Extract 8 Stems From Any File of Your Choice
2022-4-1 00:01| ·¢²¼Õß: 2542790| ²é¿´: 1661| ÆÀÂÛ: 0
ÕªÒª: Obtaining individual music accompaniments used to be costly. Now, you don't have to pay a dime when you have tools like LALAL.AI at your fingertips. With this solution, you can remove vocals from a so ...
Obtaining individual music accompaniments used to be costly. Now, you don't have to pay a dime when you have tools like LALAL.AI at your fingertips. With this solution, you can remove vocals from a song with little to no effort, free of charge. When compared to other vocal remover apps, LALAL.AI utilizes well its artificial intelligence interface to allow you to extract up to eight more stems from any file. Learn how here:
How Can I Remove Voice from Audio?
Due to the technical complexity of removing complete vocals, it has always been a challenge. Fortunately, LALAL.AI provides the best and most effective solution to this problem. If you wish to remove vocals from a song, you can do so by simply visiting LALAL.AI's website. Check out below how to do it with only a few steps:
#1 Head on to LALAL.AI in your browser. There is no need to download applications and you don't have to make an account to get started.
#2 Click 'Select Audio File' where you can choose any format, length, and size. (Before this, choose which type of music stem you want to extract. In this case, choose 'Vocal and Instrumental.)
#3 After following step #2, a folder window will open up. Double click an audio file to upload it on LALAL.AI
#4 The vocal remover will get started right away, just wait a few seconds until it's finished.
#5 To see how clean it can remove vocals from your chosen song, click the play icon located in the Instrumental Preview section.
When adjusting the level of audio filtration, you have the option to select three different levels. By default, the setting is 'Normal.' 'Mild' features a minimum amount of sound filtration. While 'Aggressive' has the maximum volume of sound filtration.
#6 Finally, download the output once it's done in the same format and quality of your chosen audio file. You can either download it directly on your device or send the link of the extracted vocal and instrument to your email.
What Is the Best Vocal Remover?
When you plan to remove song vocals, splitting this single stem is not enough, especially if you're looking to create tracks on your own. LALAL.AI is one of the fastest-performing, easiest, and most precise software for stem extraction of vocals from any audio or video.
LALAL.AI
It features a next-generation vocal remover and source separation service that allows you to extract 8 stems: vocal, instrumental, instruments like drums, bass, piano, electric guitar, acoustic guitar, and synthesizers without sacrificing the quality. Among all AI splitters, you don't just get to remove vocals from a song. You can do more.
Features
  • Seamless API Integration: You can now expand your business with LALAL.AI Business solutions. The vocal remover's programmatic interface allows your team to use its service with any process or tool. Improve your scalability without adding any unnecessary complexity.
  • 8-Stem AI Splitter: After the addition of the sixth musical instrument you can extract, LALAL.AI introduced the synthesizer. So besides being an instrumental and vocal remover, you can also split 7 more stems which are the following: backtracks, piano, bass, drums, acoustic, electric guitar and synthesizer -- all in all, offering 8 stems including vocal and instrumentals, the first of its kind.
  • 2 Neural Network Versions: In the beginning, LALAL.AI separated stems using Rocknet, a unique neural network they created using 20TB of training data to isolate instrumentals and vocal tracks. Then, LALAL.AI developed Cassiopeia, a neural network designed to enhance vocal and accompaniment separation techniques and expand to support individual musical instruments. Cassiopeia took over all stem isolation tasks, which was an improvement over Rocknet in every aspect. Later, LALAL.AI removed the neural network switch and all files were processed with Cassiopeia, helping you remove vocals from a song using an advanced neural network version.
  • 7 Languages Support: LALAL.AI previously offered its services exclusively in English. Later on, the vocal remover app became more accessible by offering 7 additional languages. Currently, it supports French, German, Italian, Spanish, Korean, Japanese, and Chinese (traditional and simplified). But more has yet to come in the future.
The good thing about this vocal remover is its state-of-art technology. All their stem splitting is 100% original and came from user reviews and the call from the music industry to access more stems.
In addition to their array of features, they trained their neural networks themselves. That allows them to operate independently with a higher level of accuracy and quality compared to other vocal remover apps.
At the moment, LALAL.AI is the only solution where you can split 8 stems from any file with top-notch standards and remove vocals from a song in a few seconds at the same time.
Pros
  • Has an AI-powered ability to extract eight stems from audio and video files: vocals, backtracks, piano, bass, drums, acoustic,  electric guitar, and synthesizer
  • Intelligent neural network version to let you remove vocals from a song and extract other stems with quality
  • Offers an API integration that works for businesses of all sizes
  • Supports 7 languages at the moment, including traditional and simplified Chinese
  • Lets you remove vocals from a song in just a few clicks within seconds
  • Consistently improving over time to meet your needs
Cons
  • Currently supports only 7 languages
Best Vocal Remover Online: Free!
LALAL.AI's audience grew exponentially with the product's success. In 2021 alone, the company saw 476,213 new subscribers to the voice remover enterprise who registered to use all the features. Don't miss out on the opportunity to remove vocals from a song in less than 6 easy steps! Click here to get started.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
