Soundtoys updates plug-ins to v5.3.7 - Apple Silicon Compatibility
2022-3-30 11:10| ·¢²¼Õß: xodes| ²é¿´: 1301| ÆÀÂÛ: 0
ÕªÒª: Soundtoys updates plug-ins to v5.3.7 - Apple Silicon CompatibilitySoundtoysSoundtoys has announced the release of version 5.3.7 of all Soundtoys plug-ins with native Apple Silicon support for Audio Un ...
Soundtoys
Soundtoys has announced the release of version 5.3.7 of all Soundtoys plug-ins with native Apple Silicon support for Audio Units and VST 2 formats. This update is free for all users with Soundtoys version 5 or later plug-ins.
Known Issues and Notes:
The minimum version of Logic Pro for native Apple silicon is 10.7.3. Please make sure to update your version of Logic.
Switching presets in Logic's built-in preset manager may cause instability with Effect Rack. Using the internal preset manager should be fine.
VST 3 Info
Steinberg recently released Cubase 12 with native Apple Silicon support. The Apple Silicon native version of Cubase no longer supports VST 2 plug-ins, and will only run VST 3 plug-ins. Soundtoys are currently finalizing the VST 3 versions of their plug-ins and expect to have them available for public beta very soon. In the meantime, you can still use Soundtoys plug-ins with Cubase on an M1 machine. Simply make sure to run Cubase using Rosetta 2. See this support article for instructions on enabling Rosetta 2.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
