Xodes Intros Utility Modules In 1U, 3U Formats Xodes let us know that they¡¯ve released a variety of Euro-compatible utility modules, in both 1U and 3U. The modules include an analog logic module, a gate randomizer and a sequential switch. Here¡¯s an overview of the new modules, from left to right: AC3 : Analog Computations based on inversion, addition / average and subtraction of 2 input signals, which could even be simply used as a buffer/inverter or voltage doubler when using only 1 input. GR2 : Dual Gate Randomizer, with Reset inputs, as well as Latching and Momentary outputs per channel. The first Momentary output is normalled to the next Gate input and allows generating 2 distinct, yet synchronized sets of randomized outputs. GR1/¦ÌGR2 : Single or Dual Gate Randomizer with user reversible panel, and function set via jumpers on the back (1U only). The function is just like GR2, with a smaller footprint. In ¦ÌGR2 mode, outputs can independently be set to Latching or Momentary, and there is normalization from output 1 to input 2. MLB : Malleable Logic Block, some sort of compact version of our previous logic module (LB5), with voltage control over the logic functions which are NOT, AND, OR, XOR and a D-type Flip-Flop with Reset, as well as a complementary output. SS14 : Bidirectional 1 to 4 Smart Sequential Switch, with some special features like sequence length defined by greatest of the O/I used, random mode, and normalization of the O/I jacks. |
