Black Rooster Audio release VLA-2A Mark II
2022-3-21 22:11| ·¢²¼Õß: 5642380| ²é¿´: 3565| ÆÀÂÛ: 0
ÕªÒª: Black Rooster Audio release VLA-2A Mark IIThe new and improved version of our best selling VLA-2A plug-in is here. The VLA-2A Mark II captures the beauty of opto-electronics by adding warm, breathy co ...
The new and improved version of our best selling VLA-2A plug-in is here. The VLA-2A Mark II captures the beauty of opto-electronics by adding warm, breathy compression and tube saturation to your tracks, for that unmistakable vintage flair.
A BRIEF HISTORY
The predecessor to the VLA-2A dates back to the early 1960s, when it was originally used for broadcast. Engineers quickly noticed that the tubes in this unit, as well as its multi-stage release and frequency-dependent attack and response, lend incredibly well to music production as well.
The VLA-2A was faithfully modeled to the original unit, perfectly capturing all of its character and making it an instant favorite!
The VLA-2A Mark II will throw you back in time, giving you that authentic vintage feel, without feeling antiquated, thanks to our careful refinement and added features. A true Black Rooster Audio classic, this unit is a vintage classic with a twist!
What's new?
Cell Selector (NEW)
Choose from 3 different opto-electric cells (A, B, and C), each with its own set of attack and release times.
Emphasis Control (NEW)
Keep high frequencies in check while controlling the sidechain, and preventing overmodulation.
Sidechain (NEW)
Control the gain reduction on your signal via the envelope of the external sidechain signal.
Make-up Gain (NEW)
Optimize your output signal by trimming it with the all new make up gain control.
Mix Control (NEW)
You can now mix in the compressed signal with the original one for maximum control.
Optimized GUI (NEW)
We have updated the GUI to be better fitting your DAW.
GET THE VLA-2A MARK II
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
