Ð嵀 TC Electronic G-Major 2 È¡´úÁËÎÒÐÅÀµµÄ Roland GP-8
2022-3-21 13:57| ·¢²¼Õß: hooks| ²é¿´: 964| ÆÀÂÛ: 0
ÕªÒª: The new TC Electronic G-Major 2 takes its place underneath my trusty Roland GP-8.
Goodbye to Old, Outdated Gear
I¡¯ve never been one to change out gear for the sake of changing out gear. If I find something that works for me I stick with it and learn it inside out. That way, when I need to make program changes to an effects unit I don¡¯t have to stare at it like a chicken watching a card trick. I can approach it with confidence, knowing what it can do and how to scroll through the various menus to make it happen. Having said that, I have to confess I¡¯ve recently made some changes to some effects processors I¡¯ve had in my rack for over a decade.
As anyone who deals with signal processing knows, technology moves fast, and by the time you get home and take a new piece of gear out of the box it¡¯s practically obsolete. But hey, a good piece of gear is a good piece of gear, and you don¡¯t have to have the newest, shiniest processing to sound good. For example, I¡¯ve been using my Roland GP-8 multi-effects processor since 1986 and it has been a big part of my sound.
After losing some of my gear in the recent Nashville flood, I found myself in the uneasy position of having to replace some of the equipment I had gotten to know so well. Two of the units that I lost were vital to my sound. One was a Boss SX-700 Studio Effects Processor that crackled and popped a little when I turned its knobs. Fortunately, it had really great reverbs and delays, so I gladly accepted its eccentricities. The other was a DigiTech IPS-33B Harmonizer¡ªa very smart unit that allows you to select harmonies by key and modes. You could also tell it what pitch to sound as a harmony against your melody note. That allowed me to go smoothly into key changes, do odd parts by harmonizing a minor second (half-step), or jump parts rather than having to accept only an interval of a third of fifth. I could shift from a major third to a sixth or octave by assigning different intervals in a custom harmony mode. I could also replicate a sort of synth-like string pad orchestra effect, which I¡¯ve heard on many of Allan Holdsworth¡¯s early recordings. The DigiTech also included a great detune feature, which I used as a sort of pseudo-Leslie effect. I could bring the effect in and out with a standard Ernie Ball volume pedal, which I controlled from my pedalboard downstage. The SX-700 and IPS-33B received their changes via MIDI through my Roland GP-8.
Finding a really good multi-effects processor for guitar that doesn¡¯t also include preamps and amp modeling is getting increasingly difficult. Companies tend to make their new rackmount multi-effect models all-inclusive. (¡°It slices, it dices!¡±) It¡¯s great to have those features, but to me it seems a bit like buying a Ferrari and never driving it over 55 mph. I like the natural drive of my amps, especially on the cleaner sounds. Real tube drive is so much fatter than processed distortion.
After much searching, the unit I found that was able to cop everything I needed without the additional preamp or speaker simulations was the TC Electronic G-Major 2. This multi-effects unit offers everything any guitarist could possibly need, including a variety of reverbs, delays, phase shifters, choruses, and even wah. Since it has a harmonizer built in, I was actually able to replace both the old SX-700 and the IPS- 33B processors in one fell swoop. There was a slight learning curve at first¡ªI had a hard time figuring out how and where to store my presets¡ªbut once I sorted that out, the unit was quite simple to program.
Fortunately I was able to write down the parameters from the old processors before they passed away. Once I transferred all the settings into the new unit¡ªabout 20 programs in all¡ªI still had the arduous task of tweaking and fine-tuning them. Some programs needed slight adjustments, but most fell right into place and sounded even better with the G-Major 2 than they did with the old unit.
One of the most beautiful advances I noticed with the new TC Electronic unit was how much better the EV-5 expression pedal responds to the commands. The old harmonizer always worked great but the one problem I had with it was that when I went to my pseudo-Leslie setting, I could still hear some of the effect bleeding through, even when the pedal was in the downward ¡°off¡± position. To remedy this I had to create a duplicate patch without the effect then switch via MIDI to the same setting with the Leslie on. With the new unit, I just have the one setting and can bring the effect in and out, saving me from having to do the pedal dance in the middle of a song.
It¡¯s often said that things happen for a reason. I was perfectly happy hanging on to my old processors like a comfortable pair of shoes. When they were damaged I was forced to upgrade to new gear, resulting in the best tone I¡¯ve had in years. Lesson learned? I¡¯m not sure, but it is all about the tone! Until next time, keep jammin¡¯.
Rich Eckhardt
Rich is a highly sought-after Nashville guitarist who has performed with singers ranging from Steven Tyler to Shania Twain. He currently plays lead guitar for Toby Keith, and also works as a spokesperson for the Soles4Souls charity (soles4souls.org). His new album, Cottage City Firehouse, is available at richeckhardt.com and CDBaby.com.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
