CME Introduces SWIDI inspired by Behringer
2022-3-21 12:55| ·¢²¼Õß: hooks| ²é¿´: 1092| ÆÀÂÛ: 0
ÕªÒª: Redefining the Xkey ExperienceEchoing the feel and look of the Xkey Air, the brand new CME SWIDI will make you rethink Bluetooth MIDI.SWIDI is a progressive music tool that combines the functionalitie ...
SWIDI is a progressive music tool that combines the functionalities of your keyboard controller with a step sequencer like no other.
With SWIDI you can control analog and digital devices. Completely wireless. It is the end of MIDI cables and power cords.
It's your 100% true portable solution that's fully compatible with any Bluetooth MIDI solution, including WIDI.
The key to absolute control
SWIDI gives you full control over any synthesizer or virtual instrument in your DAW via Bluetooth MIDI.
With an unparalleled 64-step sequencer, with 8-note polyphonic sequence and 32 slim keys, SWIDI takes MIDI to new heights.
Its integrated WIDI technology links SWIDI as a central controller with up to four (4) peripherals. Without wires. With and completely without computers.
Finally, you can create 1-to-4 MIDI configurations over air. Enjoy freedom on stage and in the studio with its unique wireless charging pad.
This is not a joke
Is it real?
Premium Bluetooth MIDI
SWIDI is based on Xkey technology combined with the latest version of WIDI. Access uniform communication between any device of any brand with the most advanced wireless MIDI technology currently available.
Ultra low 3ms latency between WIDI equipped devices
65ft / 20m plain sight range between WIDI equipped devices
Add up to five (5) Bluetooth MIDI devices with group auto-learn
Optimise for latency or jitter performance via WIDI App (iOS/Android)
The finishing touch....
WIDI is a 100% community-driven technology. It is validated and approved by thousands of MIDI enthusiasts worldwide. Now it is time to take the industry to the next level...
Wireless MIDI. Wireless Charging.
No redundant ports. No component shortage.
Available May 2, 2022
Retail $ 79
Contact CME for more details, questions and complaints.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
