-> A NEW PARADIGM AROUND HARMONIC SCORES CREATION, MELODIC SEQUENCES PROGRAMMATION, AND REAL-TIME NOTE INTERPRETATION -> PRESELECT THE NOTES/FREQUENCIES YOU WANT TO PLAY ¨C TWELVE NOTES OF POLYPHONY TO RULE THEM ALL -> DEFINE INDIVIDUAL TEMPO SIGNATURE & RHYTHMIC RULES FOR EACH NOTE SELECTED¡. AND LAUNCH THEM MANUALLY OR THROUGH A MODERN POLYRHYTHMIC SEQUENCER ->FIND VARIATIONS TO YOUR SEQUENCES WITH SMART POSITION & TEMPO WRAPPERS, RANDOMIZATION FUNCTIONS & POWERFUL TRANSPOSITION FEATURES. ->CHOOSE FROM CLASSICAL SCALES AND MODES, SET YOUR CUSTOM TUNINGS, OR EXPLORE UNKNOWN TEMPERAMENT SETTINGS AND MICROTONAL SCALES. REQUIREMENTS ¨C a MAC or a PC with a FULL version of Reaktor 6.4.3 (CAUTION: the .ens is not encrypted for Reaktor Player) ¨C A screen resolution with a minimum of 1920 x 1200 megapixels for a full display on the screen. COLLIDZ¡ã panel dimension is 1660¡Á1115 megapixel. ¨C Intel Core 2 Duo equivalent must be enough with 4 GB of Ram. To give an idea this ensemble has been created on a 2,7 GHz Intel Core i7. ¨C CPU usage: Around 34% and 39% with a 2,7 GHz Intel Core i7, 16G Ram, and Reaktor 6 stand-alone. A maximum of 42% have been measured with all the effects enabled. (test made with a Macbook Pro 2013 version) ¨C An internet connection to download the files and potential updates. ¨C Size : 329 Mo COLLIDZ¡ã is not compatible with REAKTOR PLAYER. For an unlimited experience with the instrument you need a full version of REAKTOR 6 COLLIDZ¡ã IS ¡ A SYNTH + A SEQUENCER + AN EFFECT PROCESSOR. A COMBINATION OF MODERN AND SPICY ELEMENTS TO COVER MANY MUSIC GENDER AND SOUND DESIGN RESEARCH.. |
