ChromaDSP CqtAnalyzer
2022-3-18 08:11| ·¢²¼Õß: 2974780| ²é¿´: 1288| ÆÀÂÛ: 0
ÕªÒª: ChromaDSP CqtAnalyzerChromaDSP CqtAnalyzerThis rainbow-colored plug-in is a spectral analyzer based on the Constant-Q transform. It features an equally-spaced logarithmic resolution across all octaves ...
ChromaDSP CqtAnalyzerThis rainbow-colored plug-in is a spectral analyzer based on the Constant-Q transform. It features an equally-spaced logarithmic resolution across all octaves, covering 48 bins per octave (1/8 tones) and ten octaves. The range and smoothing are adjustable, and you can choose from the left, right, mid, or side channels. The colorful display makes it easy to pinpoint certain frequencies. ChromaDSP says that the plug-in uses multithreading to minimize its weight on the audio thread.
CqtAnalyzer is an open-source plug-in and currently available for Windows, macOS and Linux in VST3 and AU formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
