Console 1 Mixing System
2022-3-17 11:05| ·¢²¼Õß: 76435280| ²é¿´: 811| ÆÀÂÛ: 0
ÕªÒª: 1CONSOLE 1 SOFTWARE CHANNEL STRIPSSmall desk, giant soundThe warmth of the British Class A. The smooth color of the Summit Audio Grand Channel. The historic character of the Chandler Zener-Bender. Hug ...
CONSOLE 1 SOFTWARE
& CHANNEL STRIPS
The warmth of the British Class A. The smooth color of the Summit Audio Grand Channel. The historic character of the Chandler Zener-Bender. Hugely versatile, the Console 1 Mixing System supports multiple classic analog console emulations and delivers the closest thing to a Weiss Engineering or Empirical Labs desk available. Get the perfectly modeled EQ, compressor, gate, and saturation sounds of the big desks in a compact piece of studio gear.
CONSOLE 1
Modern mixing by ear
Console 1 is the hardware centerpiece of the Console 1 Mixing System. It controls the channel strip expansions and every aspect of the preloaded software¡ªthe legendary and precisely emulated Solid State Logic SL 4000 E desk¡ªfrom the EQ and compressor to the drive and beyond. Every knob has a dedicated job so you can set up your session and mix the way you would with an analog console¡ªonly better. With no need to map parameters. Just unbox and begin.
CONSOLE 1 FADER
Even more hands-on control
Fader is a hardware unit for those whose instrument is the desk. Featuring ten touch-sensitive 100 mm Alps motorized faders and the same robust chassis found on the Console 1 hardware, Fader enhances your workflow like a genuine analog console because Fader is built like a genuine console. It gives you quick and intuitive control over volume, saturation, filtering, and more. Use alone or connect as many Faders as you¡¯d like to Console 1. It's your world. And Fader gives you complete dominion over it.
CONSOLE 1 READY
PLUG-INS
The dream console
Love the aggression and tasty distortion of FET Compressor? You can go all-buttons-in with Console 1. Looking to harness the powder-keg personality of the original Valley People Dyna-mite processor? Strike the match in Console 1. All your favorite Softube and UAD emulated plug-ins are available for the Console 1 Mixing System. Replace any section with a Console 1-ready plug-in and create your very own custom console. Analog desks only wish they could.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
