Black Rooster Audio VLA-2A Mark II: compressor plug-in gets big update
2022-3-16 22:46| ·¢²¼Õß: 31043840| ²é¿´: 1882| ÆÀÂÛ: 0
ÕªÒª: The Black Rooster Audio VLA-2A is the developer¡¯s attempt to bring the LA-2A opto compressor from the late 50s to the modern age in plug-in form. In addition to a faithful model of an original unit, ...
The Black Rooster Audio VLA-2A is the developer¡¯s attempt to bring the LA-2A opto compressor from the late 50s to the modern age in plug-in form. In addition to a faithful model of an original unit, VLA-2A Mark II offers an impressive set of expanded features that let you get more ¨C or less ¨C of the LA-2A¡¯s characteristic compression. VLA-2A Mark II is a major update that brings plenty of new functionality and optimizations to the plug-in. The developer has also put it on an introductory sale for a brief time.
VLA-2A Mark II from Black Rooster Audio
Mark II has the following new features:
Cell Selector: Choose between 3 different opto-electric cell emulations, each with its own set of attack and release times.
Sidechain: Control the gain reduction on your signal from the envelope of an external sidechain signal.
Emphasis Control: Helps tame high frequencies to control the sidechain and prevent overmodulation.
Make-up Gain: Trim the output signal with the new make-up gain control.
Mix Control: Blend the dry and compressed signal for maximum control.
DSP operations are optimized using the SSE2 instruction set.
User interface optimizations and enhancements (high DPI support).
"<yoastmark
Pricing and Availability
VLA-2A Mark II costs EUR 49 through the introductory period. Owners of the original VLA-2A get the upgrade for free. The plug-in is available in 64-bit VST, AU, and AAX formats for macOS 10.9 (macOS Big Sur is not yet supported) and Windows 7 or newer. A free trial version can be downloaded from the website. All in all, VLA-2A Mark II looks like a worthwhile addition to your opto compressor plug-in collection. I like the detailed controls and opportunity to extract more depth out of the original unit¡¯s unmistakably simple and satisfying character.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
