Fugue State Audio Spectral Lemuring
2022-3-16 09:10| ·¢²¼Õß: kiive| ²é¿´: 880| ÆÀÂÛ: 0
ÕªÒª: Fugue State Audio Spectral LemuringFugue State Audio Spectral LemuringFugue State Audio says that Spectral Lemuring is inspired by Spectral Monkeyage by Shiny FX, a long discontinued freeware plug-in. ...
Fugue State Audio Spectral LemuringFugue State Audio says that Spectral Lemuring is inspired by Spectral Monkeyage by Shiny FX, a long discontinued freeware plug-in. It¡¯s a spectral processing effect that lets you process the high-magnitude and low-magnitude parts of the FFT signal separately. If that sounded too technical, Fugue State Audio says that it can be thought of as a lo-fi pitch shifter with some extra functionality. It¡¯s not the same as Spectral Monkeyage, but it does some of the same things.
Spectral Lemuring is a VST3 plug-in for Windows.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
