Behringer Intros Moog Taurus Bass Synthesizer Knockoff, The ¡®Toro¡¯ Original Moog Taurus logo Behringer today introduced the Toro, a new bass synthesizer that they describe as ¡°an authentic recreation of the legendary Moog Taurus Revision 1¡±, but without the foot pedals. In addition to copying the Taurus design, the new Behringer synth uses a knockoff name and logo. The Toro is scaled down to fit into Eurorack format and can be removed from its case for rackmounting as part of a larger system. The synth is a dual-VCO VCF VCA design, with envelopes for filter cutoff and volume. The synth also features four preset sounds (Tuba, Bass, ¡®Toro¡¯ and Variable), like the original. Features: Classic Analog Bass Synthesizer with 2 VCOs, Ladder Filter and Presets in Eurorack format Recreates the circuit design of the Taurus I bass synth Analog signal path 2 VCOs 5-octave range VCO A and B mix fader for full control of the internal balance Classic low-pass ladder filter with Cut-off and Emphasis controls Envelopes for filter cut-off and amplitude 4 ¡®magic-sound¡¯ presets: Toro, Tuba, Bass and Variable Glide, featuring Amount slider and a dedicated On/Off button Large Filter cutoff and Volume knobs CV, Filter cutoff and Gate inputs for external control 16-unit Poly Chain allows combining multiple synthesizers for up to 32 voice polyphony Eurorack format 23 controls give real-time access to key parameters MIDI implementation with MIDI channel and Voice Priority selection Behringer has not shared any audio demos at the time. Here¡¯s an example of an original Moog Taurus 1 in action: Pricing and Availability Behringer says that the Toro synthesizer is fully developed, but production is waiting on chip availability. The price that they are targeting is $199 USD. |
