Stagecraft Software Delay, BitCrusher and AutoFilter Stagecraft Software Delay, BitCrusher and AutoFilterStagecraft Software offers not one, but three free plug-ins with great feature sets and good-looking GUIs. Delay is a filtered delay effect with spectrum displays. BitCrusher is a full-featured bit crusher that includes a noise generator, LFO-controlled filter and stereo spreader. And AutoFilter is a filter plug-in designed with electronic music in mind, which lets you modulate and automate all filter parameters. All three plug-ins are free, but the developer asks that you register after 30 days. The Stagecraft Software plug-ins are available for macOS and Windows in VST, VST3, AU and AAX formats. Delay Plugin delayProduct A quantizing, dual band Delay designed with EDM music in mind. Our delay is the only one out there to show you the spectrum response as you play, so you can literally see the effect it has on the audio. more ¡ Mac Win BitCrusher Plugin delayProduct SC Bitcrusher is a full-featured bitcrusher plugin that lets you control bit rate, rate reduction, and stereo spread (with stereo field visualization). We¡¯ve also added a filter section that allows you to add filtered noise to the mix. more ¡ Mac Win AutoFilter Plugin SC Autofilter gives you all the essential functionality you would expect from an autofilter, along with features designed specifically with the DJ/electronic musician in mind. Parameters are fully automatable, quantizable, and a display showing filter response and output FFT allows you to see the filter¡¯s effect in real-time. more ¡ Download the free plugin https://www.stagecraftsoftware.com/products/free-plugins/ |
