New module: CVM-8 now available
2022-2-25 14:26| ·¢²¼Õß: noisebud| ²é¿´: 557| ÆÀÂÛ: 0
ÕªÒª: New module: CVM-8 now availableWe're delighted to announce a new Eurorack module, the CVM-8.The CVM-8 is an eight channel CV to MIDI and CV to I2C converter. Its two independent MIDI ports can be used ...
The CVM-8 is an eight channel CV to MIDI and CV to I2C converter. Its two independent MIDI ports can be used with any MIDI device via 5 pin DIN or TRS 3.5mm jack breakouts, or connected directly to other Expert Sleepers modules via their MIDI breakout headers.
Compatible Expert Sleepers modules include the disting mk4, FH-2 and ES-9 (MIDI only) and the disting EX (MIDI and I2C). Compatible breakouts include the MIDI Breakout and the Tiny MIDI Breakout.
The CVM-8 also sends on the Select Bus, so no wiring is required to drive, for example, the disting EX.
As an added bonus, the module provides I2C-to-MIDI functionality.
The CVM-8 is available immediately, stock permitting - see Where To Buy.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
