Noisebud releases NoLias - a plug-in to help you avoid aliasing
2022-2-25 07:28| ·¢²¼Õß: 8203130| ²é¿´: 740| ÆÀÂÛ: 0
ÕªÒª: Noisebud releases NoLias - a plug-in to help you avoid aliasingNoisebudNoisebud has released NoLias, a plug-in that lets you quickly determine if there are any aliasing artifacts in a mastering- (or m ...
Noisebud
Noisebud has released NoLias, a plug-in that lets you quickly determine if there are any aliasing artifacts in a mastering- (or mix-) chain.
NoLias runs a customized sine sweep through your chain, if there are any aliasing, you'll hear it immediately.
NoLias is only available at Noisebud's Patreon site, for the $5 membership you'll get to download all the Noisebud branded plugins.
Read more at
www.patreon.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
