SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks! Frequency Central Blades Of Ingenuity packs a looping AR envelope generator, a triggerable LFO and a circuit with twists in a 4HP module. Modules that offer a lot in the smallest of spaces are ideal. King of the function/space modules is Expert Sleepers disting mk4. This packs more than 100+ functions into a 4HP module. A fascinating module, but also one that requires a lot of menu diving from the user. There is also the most radical counterpart. Less but very hands-on and classic. Frequency Central¡¯s new module with the intriguing name ¡°Blades Of Ingenuity¡± does just that and follows the concept less is more. Frequency Central Blades of Ingenuity Blades of Ingenuity is a new modulation module that consists of two elements. It squeeze an loopable attack/release envelope and an LFO in a 4HP module. The attack/release envelope gives you a one shot and a looping mode with a looping range from 19 Hz to 5 seconds. Then, you have a low frequency oscillator with multiple waves: sawtooth, triangle and ramp switch. It range from 19Hz to 60 seconds and offers an external retrigger option. A wilder side can be unlocked in the module via cross-patching. With this you can create more unique and unusual waveforms. For example you can patch the A/R out to LFO reset in and LFO out to A/R gate. Both times with active loop mode on the A/R envelope. You can see the module in action in the linked demo video. A very useful modulation module with some interesting twists that takes up very little rack space. Frequency Central Blades of Ingenuity is available now fully assembled for ¡ê100 + VAT + shipping. There are also different DIY options including the full kit for ¡ê50 + VAT + shipping. |
