Fazertone The Klone
2022-2-18 09:49| ·¢²¼Õß: 43265900| ²é¿´: 748| ÆÀÂÛ: 0
ÕªÒª: Fazertone The KloneFazertone The KloneFazertone has taken on the challenge to clone the famous Klon Centaur, one of the most iconic distortion pedals of all time. The developer says that they¡¯ve used ...
Fazertone The Klone
Fazertone The KloneFazertone has taken on the challenge to clone the famous Klon Centaur, one of the most iconic distortion pedals of all time. The developer says that they¡¯ve used a combination of circuit analysis and a custom neural network engine to accomplish this feat. Just like the original, the plug-in only has three simple controls: gain, treble and output. Fazertone says that it brings the transparent overdrive and crisp distortion of the Klon Centaur straight to your DAW.
The Klone is available for macOS (M1 supported) and Windows in VST3 and AU versions. An AAX version is in the works.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
