2B Played Music releases 2B Clipped 3 VST3/AU plug-in with Intro Offer
2022-2-16 09:05| ·¢²¼Õß: 62417940| ²é¿´: 615| ÆÀÂÛ: 0
ÕªÒª: 2B Played Music releases 2B Clipped 3 VST3/AU plug-in with Intro Offer2B Played Music has announced the release of its new clipping effect 2B Clipped 3, a tool to provide your guitar leads, basslines, ...
2B Played Music has announced the release of its new clipping effect 2B Clipped 3, a tool to provide your guitar leads, basslines, synth leads, kicks, percussion and maybe even vocals with unique analog clip distortion.
They say:
For 2B Clipped 3 we built 2 clip distortion engines with different analog characters. In addition to the gain and mix knob, we have added a low pass and high pass filter to specify exactly which part of the sound you want to distort. Once you've started using the plug-in, you'll see that if the dynamic range is exceeded, volume compensation will automatically occur.
In this way you can distort the signal to the maximum without detecting your DAW clipping in the mixer.
Price: 16,36 Excl. VAT. A 35% introductory discount applies until February 28th, 2022, at 2bplayed.com
Read more at
2bplayed.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
