USB Extender With both 1U and 3U panels Up Top! Extends any Micro USB connector on the back of a module to the front panel of your modular case. Get it $39.00 Bring that USB connector to the front! Originally designed for the Metropolix 1.4 USB MIDI update, the USB Extender extends the USB Micro connector on the back of a module, bringing it to the front panel for easy connection to your USB Host. USB Extender comes with both 1U and 3U panels* 1U The 3U panel, includes a dual passive mult, which is great for splitting output signals to other modules. You can swap the panel with a Phillips-head screwdriver. The 1U panel does not have mults. Also included is a 60CM Right-Angle Micro USB to Micro USB cable for routing the connection beneath the modules. |
