INTERNET Co. "V Monitor" VST/AU Plug-in to five different types of speaker
2022-2-13 07:54| ·¢²¼Õß: 76968720| ²é¿´: 788| ÆÀÂÛ: 0
ÕªÒª: INTERNET Co. releases "V Monitor" VST/AU Plug-in to emulate five different types of speakerINTERNET Co. has released V Monitor, a VST/AU effect plug-in for Mac OS X and Windows.Here's what they say:V ...
V Monitor is designed to emulate five different types of high-grade speaker.
Acoustic characteristics of each speaker are derived from impulse response recordings of actual speakers and have high reproducibility in sound. V Monitor is convolution-based simulator. Even in using headphones or earphones, sound field of speakers can be simulated and optimized by adjusting the amount of Space. Also you can adjust Bass and Treble.
V Monitor works as a very convenient tool for mixing.
Acoustic characteristics in monitoring with speakers can be confirmed by inserting to master output section in DAW.
Price: $68.
*V Monitor effects differently depending on the characteristics of speakers, headphones and earphones you use.
*V Monitor is not a standalone software, VST / AU host applications (64-bit compatible) are required.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
