modular diy FEBRUARY-POSTED BY TOBIAS VON HOFSTEN
2022-2-12 08:51| ·¢²¼Õß: 5698400| ²é¿´: 726| ÆÀÂÛ: 0
ÕªÒª: modular diyto mark the release of the individual POM modules, we've put together three diy projects for your inspiration. each one uses separate modules from the POM range in very different setups. a ...
modular diy
to mark the release of the individual POM modules, we've put together three diy projects for your inspiration. each one uses separate modules from the POM range in very different setups. a playful lego mechanical lfo, a sturdy jamaican inspired dub siren, and a portable usb-powered business modular.
SQUARE BOX
strictly business
this project is using all the modules from the POM-400 kit, together with the eurorack front panels from oddvolt mentioned in an earlier blog post. the case chosen is an auer esd euro case with an added handle. the eurorack frame is from clicks & clocks, cut to size in our workshop. for power we opted to go with a portable usb solution using the dedicated usb power cable from myvolts, connected directly to the psu, and powered by a powerful anker powerbank. the power distro is used to distribute the power to all the modules. here are some links to the external parts used.
DUB SIREN
dub siren from space
inspired by a little aluminium siren effect box that was lying around the office, we decided to build our own enhanced version, with an lfo, a square module and a psu. we then added a line-level output, a 9V battery and a guitar pedal power jack. the green knobs select between different pre-patched connections that you can override by inserting something into the jacks. there's a little more info on the build process over on speedbjorns instagram.
MECHANICAL LFO
mechanical lfo
need an extra, sine-shaped lfo? of course you do. here we built a lego robot using a lego motor, gearbox and rod to control the tune knob of any wave generator. here the sine wave oscillator is used. very handy!
individual modules for your projects
we hope this can spark your imagination and encourage you to explore and share your own modular projects. all individual modules are available in our webstore. mount them in your existing eurorack, using external panels, or create something fully custom and one of a kind. enjoy!
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
