Final Mix Software releases Analog Fusion console emulation plugin
2022-2-10 09:04| ·¢²¼Õß: 8956520| ²é¿´: 873| ÆÀÂÛ: 0
ÕªÒª: Final Mix Software releases Analog Fusion console emulation pluginFinal Mix has has modeled some of the most popular consoles in history and fuses them together in a single plugin. A true analog conso ...
Final Mix has has modeled some of the most popular consoles in history and fuses them together in a single plugin. A true analog console emulation at its finest, Analog Fusion aims to faithfully capture the magic of analog recording consoles.
It¡¯s undeniable. There is magic in the sound of analog recording consoles. When audio passes through the channel of a mix desk and is combined at the output section, something incredible happens. This is how Analog Fusion works. The ¡°Channel¡± knob is designed to enhance the sound of individual tracks, and the ¡°Console¡± knob is designed for Aux inputs and the Master Fader. But, that¡¯s just the beginning. Let your ears be the judge and use Analog Fusion any way you like. It¡¯s awesome.
Available for Windows and Mac (VST, AU and AAX), Analog Fusion is priced $24 USD. You can get a 15% discount on a purchase by using coupon code FREDDIE2202 at the checkout (valid on all Final Mix products until February 10th, 2022).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
