VGTrumpet releases "VG Ethnic Flutes" for Kontakt with Intro Offer
2022-2-8 12:13| ·¢²¼Õß: deluxe| ²é¿´: 525| ÆÀÂÛ: 0
ÕªÒª: VGTrumpet releases "VG Ethnic Flutes" for Kontakt with Intro OfferVGTrumpet has released VG Ethnic Flutes for the full version of Kontakt.Details:Set up to work with breath controllers (TEControl, MRT ...
Details:
Set up to work with breath controllers (TEControl, MRT Audio, Yamaha BC3), wind controllers (AKAI EWI, Yamaha, Aerophone AE-10, AE-20, Pro AE-30) and MIDI keyboard controllers.
WAV files can be used directly in your DAW, or any other sampler plugin for further editing.
More than 330 unique samples.
VG Ethnic Flutes require the full retail version of Kontakt 5.6.8 or later (Kontakt Player is not supported).
Recorded sample quality: 24-bit / 48 kHz.
Custom designed, unique GUI.
Effects: Expression, Vibrato, Wah, Flutter tongue, Attack (accented beginning of the sound), Breath (noise of air passing through the instrument).
Reverb, delay and stereo control to fit the instrument in every mix.
Best Balance of Natural Velocity Resolution and Data Size.
Library Size: 314 MB.
Up to 4 velocity layers per key.
Flutes played by Javier Martin, Gennady Petrov, Ana Ruiz.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
