discoDSP releases Bliss 2.0 - Sampler and instrument recorder
2022-2-7 13:27| ·¢²¼Õß: 5987160| ²é¿´: 1390| ÆÀÂÛ: 0
ÕªÒª: discoDSP releases Bliss 2.0 - Sampler and instrument recorderdiscoDSP has updated the Bliss sampler and virtual instrument recorder to release 2.0 for Windows, macOS and Linux.What's new:Native Apple ...
What's new:
Native Apple Silicon (M1 or higher) support.
Major framework update with greater stability and compatibility.
Added dragging behavior for velocity, key range and tempo selection.
Added export single selected file.
Added exported file to recent sample list.
Added Program name as default filename after exporting.
Added Rubber Band time stretch library by Breakfast Quay.
Added save selected zone in Bliss program.
Fixed amp_env_dest1amt XML parameter saving.
Fixed incorrect parameter range initialization.
Fixed note sharp character not displayed correctly.
Fixed note sharp character not exported correctly.
Fixed Replace Sample function.
Fixed standalone background color settings.
Fixed VST sampling settings preset combo box.
Last SFZ exported folder now recalled correctly.
Sample and zone export now uses 24-bit instead 16-bit.
Set zone by MIDI note now mirrored in Options and Zone menu.
Minor fixes and enhancements.
Bliss can be upgraded from 1.x for
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
