| Korg miniKORG 700 Available Again After Almost 50 Years Korg announced today the availability of the miniKORG 700, a modern reissue of the company¡¯s first mass-produced analog monosynth. The miniKORG 700 FS is a full-size reissue of the two-oscillator ¡°S¡± model, but incorporates a few modern updates, including an arpeggiator, built-in spring reverb, aftertouch, improved connectivity and more. The miniKorg 700 FS was developed in conjunction with the original designer, Fumio Mieda. The miniKORG 700 FS is being offered as a limited-edition release, with a custom case. |
