Stoff Audio Dystortion
2022-1-30 11:38| ·¢²¼Õß: wandong| ²é¿´: 639| ÆÀÂÛ: 0
ÕªÒª: Stoff Audio DystortionStoff Audio DystortionDystortion is the first plug-in by Stoff Audio. The developer says that he comes from an audio engineering background and didn¡¯t have much prior coding exp ...
Stoff Audio DystortionDystortion is the first plug-in by Stoff Audio. The developer says that he comes from an audio engineering background and didn¡¯t have much prior coding experience. But he set out on a long journey to teach himself C++ and the JUCE framework to create this distortion plug-in, which works just as well on guitar and bass as on everything else. If that doesn¡¯t deserve a donation, I don¡¯t know what does! The plug-in¡¯s only control is a large gain knob that lets you dial in the amount of distortion.
Dystortion is available for Windows and macOS in VST3, AU and AAX formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
