GuDa Audio updates KickR with new grain section and Mac M1 support GuDa Audio has updated KickR to v1.8. KickR has gained a new section "grain" to add body and thump noise. It is granular sample based with controls to change EQ, length and a ducking feature that makes is "rattle" in tune with the kick, always keeping the rattles on low volume part of the sound so the kick always remains as loud as without the rattle. It is available as VST/VST3 and AU for Mac and VST/VST3 for windows for 24$. |
