Yet Another Limiting Amplifier "YALA" v5.0 - Analog Obsession Iconic Vari-Mu limiting amplifier with extra features! Features - VOLUME: -30 to +30dB input volume to drive circuit. You can drive circuit and get saturation plus more compression or vice versa. - ATTEN: Output volume to adjust final level after process. - THRESHOLD: Will let you set threshold to make compressor works. If you use VOLUME knob to boost input, you can leave THRESHOLD at default position and get mojo slightly compression. It has 30dB range. - RELEASE: 300ms to 1.5sec release time - HPF: 20 to 500Hz HPF to keep low frequencies from sidechain circuit. So, compressor won¡¯t touch to low-end. - EXT-SC: This will let you use external signal to compressed input signal. - POWER: Plugin Bypass (Big Red Light) - ANALOG OBSESSION: Oversampling (Label) *Fixed Attack Time: 10ms *Removed MIX option. Will be added with next update. Available Formats VST/VST3/AU | Mac 10.9 - 11.X VST/VST3 | Windows 7 - 8 - 10 Version 5.0 - Improved DSP and circuit design - Added 4x oversampling - Readout for knobs - Redesigned GUI - Catalina & Big Sur(Intel/M1) support Patreon |
