New Decimator Bitcrusher In 1U
2022-1-23 07:53| ·¢²¼Õß: tapco| ²é¿´: 822| ÆÀÂÛ: 0
ÕªÒª: New Decimator Bitcrusher In 1UMosaic has introduced Decimator, a 1U DSP bitcrusher, with independent bit-depth and sample-rate reduction.Here¡¯s what they have to say about it:¡°Bit reduce and downsam ...
¡°Bit reduce and downsample audio into oblivion with Decimator. Lo-Fi sweet spots are just a knob turn away with independent control over each decimation aspect, and a dedicated dry/wet mix knob to bring the heat when you want it. Effortlessly turn your karplus-strong plucks into heavy metal power chords, or harmonically complex samples into 8-bit chiptune goodness within a single module. Sonic destruction is a patch away with Decimator!¡±
Features:
High Fidelity 96kHz, 24-bit audio engine
Multifaceted decimation DSP effect
Downsampling
Bit depth reduction
Mix between dry and wet signals
Note: Mosaic panels conform to the Intellijel 1U format, but Pulp Logic style panels are also available.
Pricing and Availability:
Decimator is available now for $119 USD.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
