Blue Cat Audio releases "Connector" Streaming Plug-in
2022-1-23 07:29| ·¢²¼Õß: tapco| ²é¿´: 677| ÆÀÂÛ: 0
ÕªÒª: Blue Cat Audio releases "Connector" Streaming Plug-in
Blue Cat Audio
Blue Cat Audio has released Blue Cat's Connector, a new universal connection plug-in that can be used to route audio and MIDI almost anywhere "in the box".
Also described as a "virtual cable for your virtual studio", Connector can stream audio and MIDI in real time, between any locations that can load plug-ins, inside one or several applications, on one or several machines connected to a network.
The plug-in offers total control over the streaming to achieve the lowest possible latencies (down to 0 samples, when used in a single application), and its built-in resampling and drift compensation algorithms take care of any potential synchronization issues between hosts for a very stable connection, even when no master clock is available.
Blue Cat's Connector Main Features:
Universal connection plug-in available in VST, VST3, AAX or Audio Unit format.
Create your own audio/MIDI routings inside your DAW (feedback loops allowed).
Create connections between any audio software on one or multiple computers.
Minimal latency, with full control over buffering.
Supports multiple sampling rates on a single connection (built-in resampling).
Built-in drift compensation.
Send and receive back audio/MIDI with a single instance.
System requirements:
Intel or M1 Mac running Mac OS 10.9 or newer.
PC running Windows Vista or newer.
Introduction Pricing: 39 USD/EUR (Reg. 49 / 20% off) until February 20th, 2022.
Read more at
www.bluecataudio.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
