D16 Group SilverLine Collection - Effects Plug-in Bundle
2022-1-20 08:30| ·¢²¼Õß: 2654380| ²é¿´: 1799| ÆÀÂÛ: 0
ÕªÒª: Ten Outstanding Creative Effects from D16 GroupWith the D16 Group SilverLine Collection, you'll get 10 amazing effects plug-ins that give you incredible sound design potential. Synthesists, producers, ...
With the D16 Group SilverLine Collection, you'll get 10 amazing effects plug-ins that give you incredible sound design potential. Synthesists, producers, and sound designers at Sweetwater have been impressed with D16 Group's software instruments, and we're excited to see ¡ª and hear ¡ª the same attention to detail and rich sound in their effects plug-ins. This bundle covers everything from versatile distortion and bit crushing to lush reverb, vibrant chorus, and phaser effects. Looking to add new layers of excitement and depth to your mixes? Load up with the D16 Group SilverLine Collection plug-in bundle.
Spacerek Virtual Space Reverb
Want to immerse your music in hyperrealistic, real-world spaces? Then instantiate D16 Group¡¯s Spacerek on a track. This reverb plug-in¡¯s unique hybrid room algorithm employs emulated virtual environments to create inviting, authentic-sounding early reflections, along with a dynamic delay network to generate lush, colorful late reflections. A 3-channel mixer gives you individual control over your direct signal, early reflections, and late reflections, plus you get individually adjustable pre-delay, a tilt EQ, and a low-cut filter for fine-tuning your sound. Spacerek includes a total of 114 stunning reverb models with preconfigured left-right and mid-side stereo operation. You'll also benefit from Spacerek's CPU-friendly performance, resizable interface, and easy-to-navigate tag-based preset browser.
Syntorus 2 Triple Path Analog Chorus
A flawless emulation of vintage bucket brigade chorus units, Syntorus 2 offers three separate delay lines for creating impossibly lush modulation. To set the rate and depth of the modulations, tap into Syntorus 2¡¯s triple-LFO section, which offers a number of waveshapes, tempo sync, and selectable note divisions. On top of that, Syntorus 2 treats you to an onboard tremolo and a multimode filter, with highpass, lowpass, and bandpass settings, for sculpting the tonality of the effect. To paraphrase a classic saying: don¡¯t bore us; give us the chorus!
Godfazer Advanced Modulation Unit
When you want to stack layers of modulation using a single plug-in, Godfazer is the go-to choice! Comprising three modules: Ensemble, Multi Filter, and Modulator, Godfazer is versatile yet intuitive, allowing for complex signal shaping with a no-nonsense workflow. Inspired by vintage modulation devices, including classic chorus effects, rotary speakers, and phaser units, Godfazer excels at throwback tones, yet its configurable routing topologies empower you to create totally unique sounds unachievable using hardware processors. As D16 Group aptly describes it, Godfazer is the Swiss Army knife of modulation effects!
Redoptor 2 Vintage Tube Distortion
With its retro aesthetic and wide palette of rich tube color, the D16 Group Redoptor 2 plug-in is primed to please tube fanatics everywhere. Redoptor 2 faithfully models the juicy harmonics, glassy partials, and beefy low end of a variety of real tube-driven circuits. Onboard compression and limiting ¡ª new for version two ¡ª and a full-featured parametric EQ dial in devilish degrees of analog warmth and breakup. Other new features include two alternative GUI sizes to support your workflow, tag-based browsing for quick access to classic favorites, and onboard MIDI learning to integrate your favorite hardware controllers. Warm up, crunch up, or obliterate your audio in exciting, hands-on ways with the D16 Group Redoptor 2.
Fazortan 2 Controllable Space Phaser
Fazortan 2 is the software expression of a classic 1970s-era hardware unit. To bring you even closer to the authentic analog vibe of the original, D16 meticulously modeled the all-pass circuits that are responsible for phase shifting. With a GUI that gives you total control over all phase shift parameters, Fazortan 2 lets you zero in on the desired contour with high precision. Guitarists, keyboardists, and vintage synth connoisseurs alike will appreciate Fazortan 2's rotary speaker emulation, and this, together with its lush sound, gives you the perfect ingredients for a glorious signal chain.
Toraverb 2 Space Modulated Reverb
With Toraverb 2, D16 Group presents an entirely fresh reverb plug-in ¡ª one that's not based on legacy hardware reverbs or impulse responses of physical spaces. Using a novel diffusion network design center on modified all-pass filters, Toraverb 2 eliminates unflattering flutter echoes to deliver remarkably smooth ambience. Two parametric EQs, modulation controls, and realistic crosstalk empower you to craft your ideal reverb sound for any application, and a built-in ducker cleans up the sound field and prevents mixes from becoming dull and muddy.
Tekturon Multitap Sequenced Delay
Much more than your standard multitap delay, the Tekturon employs a sophisticated delay matrix to manipulate its 16 independent high-quality delay lines. Think about it as a delay sequencer with an intuitive interface for concocting mind-boggling echo effects with relative ease. A global effects section features a master filter control with cutoff and resonance, a feedback control, and a shuffle control for humanizing tempo-synced delay patterns. Additionally, each delay line has localized parameters, including stereo pan, spread, volume, delay time, feedback, and individual filter settings. Tekturon is unlike any other delay plug-in available, and it¡¯s certain to invigorate your arrangements.
Decimort 2 High Quality Bit Crusher
Sweet decimation! The D16 Group Decimort 2 bit crusher plug-in re-creates the sonic coloration of the AD/DA converters found in old-school samplers, like early AKAI and EMU samplers. Use it to give individual tracks a certain edge, or automate it for extreme sound mangling. Electronic musicians at Sweetwater rejoiced at Decimort 2's fat-sounding filter section, with four filter types to choose from. Even better, you can process each channel of a stereo signal independently, opening the doors for a wide range of space-enhancing effects. Plus, Decimort 2 is endlessly tweakable, with adjustable jitter, two quantization algorithms, a multimode filter, and more.
Devastor 2 Multiband Distortion Unit
Add bite, sizzle, and sonic intensity to your tracks and mixes with the D16 Group Devastor 2 multiband distortion plug-in. It emulates diode clipping and offers analog-modeled filters for extremely smooth sonic performance. Use it to add some excitement to high frequencies, add body to low frequencies, hype a vocal's midrange, and much more. Recording engineers at Sweetwater know that distortion is an extremely useful tool for mixing, and not just for special effects. Get a multiband distortion plug-in that can sound as subtle or severe as you want ¡ª the D16 Group Devastor 2 plug-in.
Antresol Analog BBD Stereo Flanger
The D16 Group Antresol drenches your guitar riffs and synth lines in a rich character that harkens back to those familiar with bucket-brigade-device-style effects stompboxes of yesteryear. Essentially a delay feedback loop controlled by an LFO generator, Antresol delivers everything from subtle thickening to swirling jet plane effects. Antresol's hardware emulation is remarkable ¡ª it's clear that D16 Group went to great pains to model every aspect of the analog circuitry that inspired its design.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
