NoiseAsh Audio releases NEED Preamps - 4 Classic British Preamps
2022-1-19 08:44| ·¢²¼Õß: michael| ²é¿´: 2364| ÆÀÂÛ: 0
ÕªÒª: NoiseAsh Audio releases NEED Preamps - 4 Classic British PreampsNoiseAshNoiseAsh Audio has released NEED Preamps under their British NEED Preamp and EQ Collection series.NoiseAsh Audio says:This bundl ...
NoiseAsh
This bundle includes the most famous 3 British Class-A and 1 British Class-AB preamps in one package; NEED 73, 81, 84, and 31102. Countless hit records have the "mojo sound character" of this British gear we've modeled accurately and crafted expertly. The Class-A transistor preamp makes the audio sources feel alive using unique vintage warmness, boldness, clarity, and unique analog saturation with anti-aliasing tonal quality. Thanks to its CPU-efficient low DSP usage, you can easily use Need preamp plugins as multiple instances, sounding just like classic greatest hit records.
NEED Preamps includes 2 plugins: NEED Pre Trilogy (73, 81, 84 Preamps in one plugin) and NEED Pre 31102.
NoiseAsh Audio continues:
Innovative NoiseAsh technology has given analog reality with a very light CPU usage. Need Preamps bundle is above and beyond for just an emulation. It's what you need for letting you enjoy all the signature warm "mojo" tones of the mythical professional studio equipment, right in your DAW, in-the-box, very easily.
Features:
Circuit reproduction of the "most desired" 3 British Class-A and 1 Class-AB preamp: NEED Pre Trilogy (73, 81, 84) and NEED Pre 31102.
For NEED 73 & 84: Class-A Mic (from ¨C80 dB to 0 dB) and Line (from +10 dB to 0 dB) Preamp model with output gain compensator (Drive Mode).
For NEED 81: Class-AB Mic (from ¨C80 dB to 0 dB) and Line (from +10 dB to 0 dB) Preamp model with output gain compensator (Drive Mode).
For NEED 31102: Class-A Mic (from ¨C80 dB to 10 dB) Preamp model with output gain compensator (Drive Mode).
Pad and Phase Inverter modes.
Anti-Aliasing Analog Modeling Engine.
Resizable GUI.
Intro Price: $29.90 until 10 February, 2022 (Reg. $130).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
