SIENNA BASS
2022-1-15 08:18| ·¢²¼Õß: 8756850| ²é¿´: 1169| ÆÀÂÛ: 0
ÕªÒª: SIENNA BASSSienna Bass is an acoustic bass plugin created by our friend, Redjoy Reza, using the Maize Sampler. Redjoy Reza recorded his acoustic bass in his studio and hope to share its sound with all ...
SIENNA BASS
Sienna Bass is an acoustic bass plugin created by our friend, Redjoy Reza, using the Maize Sampler. Redjoy Reza recorded his acoustic bass in his studio and hope to share its sound with all the musicians . This is why this plugin is a free plugin.
Sienna Bass is very small in size, around 7MB, but its sound keeps a high standard.
DOWNLOADING AND INSTALL INSTRUCTIONS
The plugin is provided as a 32Bit & 64 Bit VST plugin under Windows System (No Mac Version yet)
Just copy and paste the dll file and the whole folder into your VST plugin folder
There is a password to extract the file.The password will be a capital letter. It will be the the first letter for the product on the left most shown below. For example, if you see the product on the left most is Neo Piano, then the password will be ¡°N¡± in this case.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
