| STEQ is based small format console eq from well known tape machine brand. FEATURES Easy to use coloration eq with variable frequency (150Hz - 7kHz) on Mid band and fixed High (10kHz) & Low (80Hz) shelf. Also, included one knob optical compressor. Each modules have their own bypass. When you bypass EQ and Compressor, preamp section will be still active. So, you can use it as line preamp. Simple but effective channel strip for you! First one in native format! Available Formats VST/VST3/AU | Mac 10.9 - 11.X VST/VST3 | Windows 7 - 8 - 10 Version 3.0 - Improved DSP and circuit design - Added 4x oversampling - Readout for knobs - Redesigned GUI - Catalina & Big Sur(Intel/M1) support Patreon |
