ttm updates free ttm000(organ) to v1.02 for Windows
2022-1-7 09:07| ·¢²¼Õß: kornen| ²é¿´: 711| ÆÀÂÛ: 0
ÕªÒª: ttm has updated their free ttm000(organ) to version 1.02.Changes:Added the function to save and load patches.Added the function to reproduce leaking sounds.Changed the presets.Changed the noise level ...
Changes:
Changed the noise level so that it can be set up to twice as large as before.
https://sites.google.com/view/ttm-works/home/vst/ttm000_eng
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
