Rockruepel Sidechain.one Boutique D¨¹sseldorf-based outboard makers Rockruepel have collaborated with prestigious recording company Studio DMI and pro-audio distributors MasteringWorks to create an unusual new dynamics processor, called the Sidechain.one. In many ways it's an ordinary compressor ¡ª it features all the usual threshold, attack, release and make-up gain knobs, plus three ratio options (2:1, 4:1 and 10:1). But it is distinguished by a pair of horizontal faders on the left of the front panel: these control a low-pass and a high-pass filter, allowing you to tune the compressor's detection signal so that it only acts on a specific frequency band. You can even 'solo' the key signal to help you precisely set the filters. Its makers tout the Sidechain.one as a versatile device, and say their implementation of key-signal filtering makes it suitable for a range of roles including de-essing, mastering, mix-bus pumping and sound design. What's more, you can link two together for L-R or M-S stereo operation. Rockruepel's Sidechain.one is due to go on sale from 15th September, and is priced at 1649 for a single mono unit or 3199 for a stereo pair. https://www.masteringworks.com |
