Shakmat Modular
2022-1-3 10:21| ·¢²¼Õß: 5236570| ²é¿´: 645| ÆÀÂÛ: 0
ÕªÒª: Evolving HarmoniesThe Bard Quartet composes and sings along with your complex harmonies! With its 4 channels and integrated keyboard, the Bard Quartet can control up to 4 different instruments which w ...
Evolving Harmonies
The Bard Quartet composes and sings along with your complex harmonies! With its 4 channels and integrated keyboard, the Bard Quartet can control up to 4 different instruments which will play together as a harmonious quartet fed by your musical ideas. Even better: the potentiometer allows you to navigate through 8 customisable harmonic progressions, leading to the creation of entire songs!
The Bard Quartet can memorise up to 320 scales (4 channels, 8 harmonies, 10 memory slots). Furthermore it includes highly customisable Microtuning and Arpeggiator options, as well as three assignable inputs and outputs.
Features
• Quad quantizer with user editable and independent scales
• Harmony potentiometer and CV input allowing to easily recall 8 different sets of scales
• User editable microtuning capabilities
• Arpeggiator with control on octave spread and mode
• Octave transposing (-3 to +3 oct)
• Non-volatile memory of 16 slots of 16 scenes
• Shared transpose input (per octave, pre or post quanitzer)
• Shared gate input acting as a track and hold or a reset for the arpeggiators
• Shared trigger output
• Non volatile memory of 10 x 8 harmonies
• Optional input interraction (normalisation or analog shift register)
• V/Oct, Hz/V and Buchla tuning compliant
• Skiff Friendly
• Djtechtools rubber injected potentiometers
• 10 hp wide
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
