Fanan team releases Midiverus - Advanced MIDI hardware router for Windows
2022-1-2 09:22| ·¢²¼Õß: 6532620| ²é¿´: 748| ÆÀÂÛ: 0
ÕªÒª: Fanan team has released Midiverus, their advanced MIDI hardware router. They say:Midiverus is a concept that allows calling any MIDI hardware that connected to the computer without any involvement fro ...
Midiverus is a concept that allows calling any MIDI hardware that connected to the computer without any involvement from the D.A.W side and connecting it to any VSTis that are opened in the D.A.W via MIDI channels. In that way, users can connect as many MIDI controllers as they wish to any opened VSTi (for instance, both their MIDI keyboard and MIDI controller to control playing and knob tweaking separately). Each route is connected to it's own unique on\off pad which can allow the MIDI signal passing to it's address. They can also determine which of their MIDI controllers gonna internally control the Midiverus pads.
Key features:
16 routing slots for any MIDI hardware that connected to the computer.
16 on\off pads, one per each routing slot.
preset manager.
internal MIDI controller selector.
Midi learn manager.
Resizable GUI.
Price: $30.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
