HoRNet updates TrackShaper to version 1.2.0 adding Apple Silicon support
2021-12-30 08:48| ·¢²¼Õß: 9271620| ²é¿´: 879| ÆÀÂÛ: 0
ÕªÒª: HoRNet updates TrackShaper to version 1.2.0 adding Apple Silicon supportHoRNetHoRNet Plugins has just released an update to TrackShaper, the tool designed to help you mix with just one knob.This featu ...
HoRNet
This feature release includes:
Added Apple Silicon M1 support.
Fixed GUI being too small on windows with hi dpi monitors.
Removed 32-bit support.
The update is free for current owners of the plugin and can be downloaded using HoRNet DoIn or from the "my account" page on https://www.hornetplugins.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
