Audioblast BreadSlicer Audioblast BreadSlicerWhat better way to illustrate what this plug-in does than with a dude slicing bread on an old-school machine? Behind the odd-looking GUI is a live auto-slicing effect. BreadSlicer takes your audio and chops it up into small slices synced to the tempo. These pieces are then rearranged randomly. You can adjust the size of the slices (1/4, 1/8, 1/16). There¡¯s also a gate slider for additional stutter effects. If you¡¯re into creative slicing effects, this one should be right up your alley. BreadSlicer is available for Windows, macOS and Linux in VST, VST3, AU and AAX formats. |
