Best Service releases The Orchestra Essentials by Sonuscore - A Fast Track to Orchestral Composing The Orchestra Essentials introduces you to our famous symphonic family. It comes with a carefully selected curation of instruments from The Orchestra, Strings of Winter, and Horns of Hell and is powered by our groundbreaking ensemble-engine. Explore the orchestral world with 99 animated themes from all orchestral sections: Strings, Brass, Woodwinds, Percussion and Choir. Immediately Playable. Incredibly Inspiring. Surprisingly Simple. Play Your Own Melodies withThe Colors Presets - Orchestral Colors are practical combinations of instruments that can be played live on your keyboard. Use them to freely play your melodies with a section of instruments. Create Complex Arrangements withSimple Chords - Create pulsating rhythms and inspiring full arrangements from any combination of notes. All of this without relying on pre-recorded phrases ¨C you have the full control. It will work, no matter what chord or note you play. Add Full Orchestral Sound in An Instant - In a revolutionary all-in-one package the sound of a symphonic orchestra is at your fingertips. With our groundbreaking ensemble-engine we found an easier way for you to convert your ideas into music. Core Features • Core Instruments • Core Presets Including Our Highly-Acclaimed Ensemble Engine - The Ensemble Engine works in the orchestra vst through a number of independent arpeggiators and velocity envelopes. Its power and ease of use has been proven in our successful The Orchestra family. Including 99 Orchestral Presets - The Orchestra Essentials introduces you to our famous symphonic family. 99 inspirational presets invite you to explore the extensive possibilities of an orchestra. Including Selected Instruments - The Orchestra Essentials provides you with a broad symphonic palette with 38 string, 12 brass and 12 wind articulations, rounded up with playable percussion and choir. The Orchestra Essentials is available now as download for |
