Suzumushi Sound Object Suzumushi Sound ObjectSound Object by Suzumushi creates binaural sound from a monaural sound source and allows you to position and move the signal freely in a three-dimensional space. Rather than convolution, the plug-in uses reflected waves in a reverberation room to achieve the effect. It also adds Doppler effect to moving acoustic sources. Don¡¯t be put off by the technical-looking GUI; once you get the hang of the top view and rear view graphs, it¡¯s actually quite simple. Sound Object is available as a VST3 plug-in for Windows. |
