Korg introduce VOX Continental 73 BK
2021-12-25 08:28| ·¢²¼Õß: zhangmin| ²é¿´: 847| ÆÀÂÛ: 0
ÕªÒª: Korg introduce VOX Continental 73 BKThe VOX Continental 73 BK stage keyboard offers the sounds you need the most, all in one unit: PIANO, E.PIANO, ORGAN, and KEY/LAYER (including brass, strings and mo ...
The VOX Continental 73 BK stage keyboard offers the sounds you need the most, all in one unit: PIANO, E.PIANO, ORGAN, and KEY/LAYER (including brass, strings and more). The front panel controls have been designed around these four parts, so first time players can easily pick it up. With its simple and intuitive layout, players have instant access to master effects, EQ, and the Nutube vacuum tube-powered valve drive.
The unit is manufactured using metal components for a sturdy design, while still being easy to play with its light-touch waterfall keyboard, all packaged in a slim, compact, and lightweight body. With its excellent portability, this is the perfect companion for keyboardists who want an instrument that¡¯s easy to play wherever you go.
I felt this was coming. Hopefully for those without the funds at the moment, this is not a limited model.
https://www.korg.com/us/products/syn...tinental_73bk/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
