New Plugin, Kora Drum, Based On The Unique DIY Instruments Of Nicolas Bras Soundpaint has introduced Kora Drum, a new virtual instrument, based on the unique DIY creations of instruments maker Nicolas Bras. Bras¡¯s Kora Drum has a body made from a tom drum, but the instrument plays more like a Lute. The original instrument is a harp-lute, with 12 strings. The Kora Drum was multisampled using several performance styles, including plucks, muted plucks and tremolos. The Soundpaint engine expands on the performance possibilities of the original, extending the range into the deep bass range and high register plucks. The intro video, embedded above, features Bras demonstrating the original instrument and composer and sound designer Troels Folmann explores the possibilities of the virtual instrument. Topics covered: 0:00 Intro 0:43 Parts 2:38 Program ¨C Drum Kora Main 2 4:04 Program ¨C Drum Kora Delay 5:17 Program ¨C Drum Kora Harp 6:23 Program ¨C Drum Kora Main Mute 7:43 Program ¨C Drum Kora Main 11:15 Hidden Gem ¨C Drum Kora Piano 12:11 Program ¨C Drum Kora Play Deep 13:21 Hidden Gem ¨C Drum Kora Prep Piano 14:05 Program ¨C Drum Kora Reversed 14:40 Program ¨C Drum Kora Textures 16:25 Program ¨C Drum Kora Trem 17:24 Program ¨C Drum Kora Tremorlo 18:22 Nicolas Bras Outro Pricing and Availability Kora Drum is available now for $20 USD. |
