Takaab SOR - Dual Passive Logic 'OR' Gate Eurorack Module
2021-12-22 10:42| ·¢²¼Õß: amper2| ²é¿´: 679| ÆÀÂÛ: 0
ÕªÒª: Takaab SOR - Dual Passive Logic 'OR' Gate Eurorack ModuleTakaab SOR Dual Switched Passive Logic OR Gate (2HP)A simple logic OR gate for use combining clock and/or gate signals. The signal path is norm ...
A simple logic OR gate for use combining clock and/or gate signals. The signal path is normalised to act as a single 7-input gate or two separate gates with 3 inputs and 4 inputs. As it is passive there is a small voltage drop of 0.7V.
Size: 1cm (2HP) x 128.5cm x 1.8cm.
https://www.siammodular.com/takaab-s...-logic-or-gate
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
