Console 1 Mixing System Mix with the sound and feel of analog. Better workflow than ever before: Check out the new updates to the Console 1 Mixing System. 1:1 hardware control over dedicated software and DAW parameters Officially-licensed channel strips from Weiss Engineering, Empirical Labs, Chandler Limited, Summit Audio, and Solid State Logic A modular system: expand it with hardware and plug-ins, and create your very own channel strips HARDWARE / ECOSYSTEM Console 1 USD 549 HARDWARE / ECOSYSTEM Console 1 Fader USD 699 The revolutionary and award-winning system that redefined mixing in the DAW, Console 1 gives you the best of all worlds: the feeling of analog hardware and the freedom of software. Far beyond a simple DAW controller, Console 1 features real console sounds from legendary brands like Chandler Limited, SSL, Weiss, Empirical Labs, and Summit Audio, plus one-to-one control over EQ, compression, and more. With plug-ins, channel strips, and the Console 1 Fader hardware unit, you can expand and customize Console 1 to your heart¡¯s content. Can an analog console do that? Give your eyes¡ªand your mouse¡ªa rest. Cross over to the future of analog mixing with Console 1. |
