FEATURES New 2022 model Stereo microphone for recording using the ORTF technique excellent stereophonic characteristics: very good localization, very good spatial quality preferred use as a main microphone for recording ensembles and choirs or as a stereophonic spot microphone The MSTC is one of SCHOEPS' bestsellers. Its compact elegance and excellent spatial quality make it a classic in the sound engineer¡¯s standard portfolio. This microphone consists of a T-shaped two-channel microphone amplifier, which two paired MK 4 cardioid capsules are screwed onto. They are arranged at a distance of 170 mm at an angle of 110¡ã to each other, as required for the ORTF method. |
