Audio Blast Intros Instalooper3 Glitch Multi-effect Plugin
2021-12-12 09:59| ·¢²¼Õß: 823280| ²é¿´: 766| ÆÀÂÛ: 0
ÕªÒª: Audio Blast has introduced Instalooper3, an audio effects plugin that features 6 effects: Gate, Bit Reducer, Autopan, Hi Pass, Phaser Time Expand.Here¡¯s what they have to say about it:¡°InstaLooper3 ...
Audio Blast has introduced Instalooper3, an audio effects plugin that features 6 effects: Gate, Bit Reducer, Autopan, Hi Pass, Phaser & Time Expand.
¡°InstaLooper3 is not a traditional loop recorder.
With this plugin, we can loop the real time audio to apply time and pitch changes to create effects on your musical creations.
It increases your workflow, because no more needs to lose hours of your time editing your sequences to create rhythm, glitch, drill, time effects.
This plugin effect is more considered like a glitch effect tool by our team, and we love to use it to create breaks at the end of measures and unstructured the sound, looping it fast to create roll effects.¡±
Features:
4 independent loops to edit.
Per loop:
An On/off loop button to activate/deactivate the loop.
12 different sizes : 1 Bar, 1/2, 1/2T, 1/4, 1/4T, 1/8, 1/8T, 1/16, 1/16T, 1/32, 1/64, 1/128.
An On/off FX button to activate/deactivate the effect.
6 integrated FX: Gate, Bit Crusher, Auto Pan, Filter, Phaser, Time Expand.
A Dry/Wet knob for the effect amount.
A parameter knob to edit each effect.
A reverse button to reverse the loop.
A On/Off Pitch button to activate/deactivate the pitch on loop.
And a Pitch knob to edit the pitch of the activated loop.
The Parameter sequencer:
16 knobs are independent and step automatable.
16 steps by parameter track.
3 play speed on each loop: /4, /2, x1.
You can edit each knob value with the step sequencer associated for each independent loop to create more glitch and interesting effects.
Loop size, Dry/Wet, Param and Pitch are fully automatable independently on each loop.
M1, Apple Silicon, Big Sur compatible ,Audio Unit, VST3, VST2, Mac Os X & Windows
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
