Klevgrand releases Rum - Room Simulator for Mac, Win & iOS with intro discount
2021-12-12 07:10| ·¢²¼Õß: 8052730| ²é¿´: 838| ÆÀÂÛ: 0
ÕªÒª: Klevgrand has released Rum, a room simulator plug-in for macOS, Windows and iOS that simulates different kinds of spaces. The plug-in gives you a versatile collection of small rooms - from acoustic tr ...
Klevgrand has released Rum, a room simulator plug-in for macOS, Windows and iOS that simulates different kinds of spaces. The plug-in gives you a versatile collection of small rooms - from acoustic treated studio booths to rooms found in an ordinary home. Rum is described as very useful to add a sense of space around dry recordings, both acoustic and electronic.
Klevgrand comments:
Recording audio from a distance is a well known technique to achieve more natural and "real" sounds. We started to elaborate with this approach and the result is Rum* - a plug-in with 10 multi-recorded rooms with different mic settings and characters that can be cross combined.
Rum offers an advanced stereo spread and modulation unit for more tweak-ability. It also comes with a built-in ducker making it easy to tame transients on the wet signal, cutoff filters, pre-delay (with tempo sync) and a full set of factory presets.
* Rum means room in Swedish.
Product Video
Feature list:
10 different rooms with 6 variants each.
3 different types of stereo spread algorithms.
Modulation.
Ducker (compression) for the wet signal.
Pre-delay with tempo synchronization.
Low cut and high cut filters.
Plenty of factory presets.
Intro Pricing until September 30, 2021:
AU/VST/AAX $29.99 at klevgrand.se (Reg. $39.99).
IOS (iPad) $9.99 on the App Store (Reg. $14.99).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
