Onsen Audio OS-251, a FREE Juno-style Lo-Fi Synthesizer plugin
2021-12-11 07:31| ·¢²¼Õß: 5228910| ²é¿´: 1097| ÆÀÂÛ: 0
ÕªÒª: Onsen Audio OS-251, a FREE Juno-style Lo-Fi Synthesizer plugin (mac, win linux)SYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, ...
Onsen Audio OS-251, a FREE Juno-style Lo-Fi Synthesizer plugin (mac, win & linux)
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
Onsen Audio OS-251 is a new free Synthesizer plugin (macOS, Windows, & Linux) combining a Juno-style design with a Lo-Fi sound character.
Synthesizer plugins don¡¯t have to be expensive. There are even very good plugins that cost nothing, see Vital, Surge, or those from Full Bucket Music. And now it¡¯s time for another free plugin.
The new company Onsen Audio has today published OS-251, a free Lo-Fi Synthesizer plugin for macOS, Windows, and even Linux.
Onsen Audio OS-251
For the development of their OS-251 Synthesizer plugin, Onsen Audio was inspired by the legendary Roland Juno-106 design. This is known to be very simple and effective. OS-251 is not analog emulation but a new synth with its own engine and character. It¡¯s a 10-voice subtractive synth that uses digital algorithms to give a warm, lo-fi character to the sound.
The core uses a single oscillator with sine, square, saw waveforms including a shape parameter. Plus, you get a square sub- & noise oscillator, and flexible pitch controls. The oscillator has alias noise (specific to digital signal processing) famous on classic samplers like E-mu SP-12 which adds a lo-fi feeling to the sound. Then, it has a bi-quad lowpass filter (LPF) and high-pass filter (HPF), each with frequency parameters. LPF has additional resonance.
Further, there is also modulation, which is as simple as in Juno. An envelope generator for the LPF & amplitude and a single LFO with sync. The latter controls LPF, amplitude, and shape parameter. At the end of the signal chain, you have a chorus effect. At the end of the signal chain, you have a chorus effect just like the original.
At first glance a nice, solid free Synthesizer plugin. There are not many features, but it is an instrument with which you can get results quickly.
Onsen Audio OS-251 is available now for free for macOS, Windows, and Linux. It runs as VST3 and AU plugin.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
